11 years agoFrame Reader IP core
Hi everyone, I'm using the DE1-SoC board from Terasic and I am attempting to display some image. Currently I am using a Qsys system that contains a NIOS II and the Clocked Video Ouput IP c...
11 years agoI have solved the problem.
It was as expected a problem with the memory latency. On my SDRAM controller are now: - the NIOS II data and instruction master - the Frame Reader master However, I had to change the arbitration for the Frame Reader to give it more priority. I found this in this (https://www.altera.com/en_us/pdfs/literature/tt/tt_nios2_system_architect.pdf) document. Right click in the Systems Contents view in Qsys. Check Show Arbitration Shares. The priority is on the point where you connect different interfaces as a number. Default is 1. I changed the frame reader priority to 50. There are still some artifacts, but that should be easy to fix. I hope it can also help someone else.
