16 years agoFrame Reader Initialization
Hello, I want to implement a Frame Reader which should read data from memory and send its AVALON Video protocol to an alpha blending mixer. My clocked video output settings for PAL are: Imag...
16 years agoChanging the files in the Qartus folder and recompiling should work.
Perhaps you need to delete the db folder before recompiling? Are you maybe using the MegaWizard to instantiate the frame reader? I found with the MegaWizard Quartus will copy the vfr files from the Quartus folder to your project folder. In this case you need to make sure the files in your project directory are also modified. When using SOPC builder, it will just reference the Quartus folder instead.
