16 years agoFrame Reader Initialization
Hello, I want to implement a Frame Reader which should read data from memory and send its AVALON Video protocol to an alpha blending mixer. My clocked video output settings for PAL are: Imag...
16 years agoI would suggest using the Test Pattern generator instead of the Frame Reader to test if the rest of your system is setup correctly. You may even want to try using just the Test Pattern Generator plus Clocked Video Output without anything else. Start with the simplest setup possible and build it up one step at a time.
