10 years agoFrame rate conversion issue
Dear reader, I'm currently evaluating (video processing) DSP IP blocks using Quartus 15.0 and Qsys 15.0 but I am experiencing some issues. I have to solve them before purchasing licenses for ce...
10 years ago --- Quote Start --- ...I believe the "afi_clk" clock rate which I use to clock the interconnect is 150MHz... --- Quote End --- Actually I believe your afi_clk will be 75MHz, as you are running the memory controller at half rate. This may explain why you had success with the lower resolution video modes, but failed with 1080p.
