10 years agoFrame rate conversion issue
Dear reader, I'm currently evaluating (video processing) DSP IP blocks using Quartus 15.0 and Qsys 15.0 but I am experiencing some issues. I have to solve them before purchasing licenses for ce...
10 years ago --- Quote Start --- The 1080p video needs a 74MHz clock, the input video is a non-standard format - what clock rate is it running at? Your QSYS diagram only shows a single clock. --- Quote End --- Thanks a lot for your reply! The input video stream has a pixel clock of 74.25MHz. Indeed the input is non-standard format, that is why I use the frame buffer for rate conversion and the alpha blender for blending with 1080p uniform background to achieve 1080p resolution. For clocked video output I use 148.5MHz to achieve 60Hz fps 1080p. regards, Richard.
