15 years agoFrame Rate Conversion - VIP Suite
Hi, I'm trying to do a frame rate conversion using the VIP Suite Megacore Function (for example : 1280*720p @ 60Hz to 1280*720p @ 50Hz). Can anyone explain me how to do or give me an exam...
15 years ago --- Quote Start --- Hi, Thanks for replying Yes, I have turned on "Frame Dropping", "Frame Repetition", "Support for locked frame rate conversion" and "Run-time control for the writer thread" I set the bit of the "Controlled Rate Conversion" register to 1 by the Nios ; the I wrote "60" to the "input frame rate" register" and "50" to the "output frame rate" register. I think I have enough memory bandwidth available for the frame buffer : the memory clock frequency is 150 Mhz the memory interface DQ width is 32 bits The memory seems to work, I found a design on internet which use frame buffer and external memory (without frame rate conversion) and it worked well. Best Regards Dath --- Quote End --- Can you give the link of where you got the design from??
