15 years agoFrame Rate Conversion - VIP Suite
Hi, I'm trying to do a frame rate conversion using the VIP Suite Megacore Function (for example : 1280*720p @ 60Hz to 1280*720p @ 50Hz). Can anyone explain me how to do or give me an exam...
15 years ago --- Quote Start --- My question is : do I have to use DDR2 memory to perform frame rate conversion, or is it possible to use an other kind of memory? --- Quote End --- As I briefly mentioned in an earlier post you can use any kind of memory as long as it has sufficient usable bandwidth and capacity. As the frame buffer accesses the memory over an Avalon MM port, the frame buffer is independent of the memory type. Any memory controller that presents an Avalon MM slave port should work.
