15 years agoFrame Rate Conversion - VIP Suite
Hi, I'm trying to do a frame rate conversion using the VIP Suite Megacore Function (for example : 1280*720p @ 60Hz to 1280*720p @ 50Hz). Can anyone explain me how to do or give me an exam...
15 years agoAre you sure you have Frame Dropping (if converting to a lower frame rate) and Frame Repetition (if converting to a higher frame rate) turned on?
Do you have enough memory bandwidth available for the frame buffer? Have you performed a memory test to make sure your memory is working properly?
