arik
16 days agoFPGA programming before XCVR's ref clock is ready
I use F-Tile Agilex 7 and Q24.2.
On power cycle (P.C) my reference transceivers clock is not ready and stable, so I do the following reset sequence to the System PLL (created for no stable XCVR's ref clock, attached):
- When P.C, setting the refclock_ready, en_refclk_fgt_0, en_refclk_fgt_1 to 3'd0, 1'b0, 1'b0, respectively.
- Stabling the transceiver's input reference clock (loading its config parameters)
- Setting refclock_ready, en_refclk_fgt_0, en_refclk_fgt_1 to 3'd1, 1'b1, 1'b1, respectively.
- Then, waiting until refclock_status, refclk_fgt_enabled_0/1 and sys_pll_locked are asserted to 1'b1
Sometimes (not often), one of the statuses on section 4 are not asserted HIGH, and thus I need to do the reset sequence again and since it fails again and again I need to do P.C again.
Is there a problem with my reset sequence? Is there a way not to P.C the FPGA and fixing this online?
Should I synchronize between the assertion of refclock_ready, en_refclk_fgt_0 and en_refclk_fgt_1?
Thanks a lot,
Arik
