12 years agoFolding inconsistencies
I have a problem with Folded design. My sample rate is clock_rate/16. So if a I have a counter inside this block, I expect one step after every 16 clock cycles. From DSP Builder manual, I understood, that I should make a design as for unfolded case. In reality, after 16 clock cycles I have 16 steps higher value. How is that in the end? Is sequential blocks are different maintained than e.g. delays? And what if I set ChannelIn folding to 16, and ChannelOut folding disabled. Does it read inputs as "latched" at every 16th cycle and process them every single cycle? Kamil.No RepliesBe the first to reply
