15 years agoFloating point numbers and latency
I have just implemented the Fibonacci design explained on the ch4 Primitive Library Tutorial. I wanted to try it using floating point numbers so i changed the parameters of the blocks, after the f...
15 years agoJust curious, why use floating point at all. I see this popping up in many posts. In fpgas floating point requires great lots of resource. If you want higher resolution why not just use fixed point of very wide bitwidth...
