11 years agoFloating Point Hardware 2 - newlib link problem
Altera said that "Floating Point Hardware 2 - newlib link problem" was solved in version 13.1. I am using version 14.1 and I can't make it work: configure: creating ./config.status confi...
10 years ago --- Quote Start --- I think you should post the code that generates the normal C summary. It looks like you have a %s corresponding to an uninitialized pointer or something along those lines. But it might be something deeper... --- Quote End --- Are you referring to the issue of this thread or the fact that my BSP takes >1 hour to build? To set the scene, I have a successfully built application that was developed under Quartus 13.1 (including the FPH 2). On 13.1 the BSP takes > 1 hour to build on a reasonably fast machine with 16 GB RAM. I am now migrating the same design (hardware and software) to Quartus 14.1 and have encountered the issue that is the subject of this thread. I would be keen to improve the BSP build speed when using the FPH 2, however my first concern is to get a successful build, which means fixing the newlib link issue.
