11 years agoFloating Point Hardware 2 - newlib link problem
Altera said that "Floating Point Hardware 2 - newlib link problem" was solved in version 13.1. I am using version 14.1 and I can't make it work: configure: creating ./config.status confi...
10 years ago --- Quote Start --- I haven't personally encountered this, but googling the error message turns up http://sourceforge.net/p/mingw-w64/mailman/message/31554323/ which has a suggestion maybe worth trying: This is a bug in autoconf. It's fixed in newer autoconf versions, butremains in configure scripts that were generated by the old ones.Patch configure script by finding the line: ac_cs_awk_cr='\\r'and replacing it with ac_cs_awk_cr='\r' --- Quote End --- I replaced ac_cs_awk_cr='\\r' by ac_cs_awk_cr='\r', in all files as they presented error during compilation. I went further, but I still can't make it work .Now, it shows a different error: C:\altera\14.1\nios2eds\bin\gnu\H-x86_64-mingw32\bin\nios2-elf-ar.exe: unable to rename 'lib.a'; reason: Permission denied Makefile:328: recipe for target 'lib.a' failed Thanks.
