15 years ago
FIR Megafunction Signed (Fractional) Binary only?
I am using Quartus II 11.0. It looks like the FIR filter Megafunction supports only Signed Binary or Signed Fractional Binary.
As far as I understand, this means that the MSB is the sign bit, and the lower order bits are the magnitude. Is that correct? Why isn't there a twos-complement option? Does it make the FIR implementation easier?
http://i.imgur.com/VD6X8.png
    --- Quote Start ---
    --- Quote End ---
    Both are 2's compliment. Signed fractional binary format results in the same hardware implementation as signed binary format, the binary point is conceptual only.
    Its quite possible the GUI displays things differently, or the coefficients can be passed in as fractional integers represented as what appear to be floating point values in a text file, but ultimately the hardware will look the same.
    Cheers,
    Dave
    --- Quote Start ---
    --- Quote End ---
    I buy that numerically it doesn't matter whether the integers are fractional or not (and I don't know why the GUI gives the option). But it seems that the signed binary representation is the same as sign-magnitude (http://en.wikipedia.org/wiki/signed_number_representations#sign-and-magnitude_method) representation, and not the same as two's-complement (http://en.wikipedia.org/wiki/two%27s_complement). The manual isn't very clear on this.
    --- Quote Start ---
    --- Quote End ---
    The manuals are not very clear on a lot of things :)
    FIR compiler will be using 2's compliment.
    Cheers,
    Dave
    Sign-magnitude is a rather inpracticable numeric format and not used by any Altera IP, as far I'm aware of. It's only an option when displaying numeric vaues in SignalTap and other tools.
