17 years agoFIR_LP Problem
I have a problem of gain with a fir_lp (value < expected value )!!! config : filtre_type : low pass sample rate :10khz cutoff freq :500hz coeff : 15 input number system : unsigned bina...
17 years agowe should start with specifications.
sampling rate: pass band: stop band: in band ripple: stop band attenuation: then we can define how many taps you need, how many bits to use, etc.
