17 years agoFIR_LP Problem
I have a problem of gain with a fir_lp (value < expected value )!!! config : filtre_type : low pass sample rate :10khz cutoff freq :500hz coeff : 15 input number system : unsigned bina...
17 years agoThere is no Altera IP for IIR filters as far as I know. MatLab or special filter tools can be used to calculate the difference equation coefficients.
