17 years agoFIR_LP Problem
I have a problem of gain with a fir_lp (value < expected value )!!! config : filtre_type : low pass sample rate :10khz cutoff freq :500hz coeff : 15 input number system : unsigned bina...
17 years agoCutoff freq is 1/20 of sample frequency, it's impossible to design a good FIR filter with 15 or 30 taps. A first or second order IIR filter will perform much better in this case.
