FIR Filter II, not able to get unity gain
Hi Chee
I think I have figured out how to use the FIR II IP to generate a LP filter with:
- Unity gain (or close to, will depend on passband ripple)
- Max calculation resolution in FIR II
- Max dynamic on the output
Here is my approach:
Generates the filter taps. E.g Matlab. Make sure sum(h(n)) = 1.
E.g. taps = 0.0001 0.0006 0.0020 0.0036 0.0028 -0.0040 -0.0173 -0.0288 -0.0212 0.0220 0.1006 0.1897 0.2493 0.2493 0.1897 0.1006 0.0220 -0.0212 -0.0288 -0.0173 -0.0040 0.0028 0.0036 0.0020 0.0006 0.0001
Pre-scaling is the trick. Do not use FIR II auto scale. This will give a non-integer scaling, and unity gain is not achieved.
To get max FIR II calculation resolution scale the taps with: 2^M / Max_filter_ripple.
Max_filter_ripple is a “compensation factor” needed to avoid overflow for frequencies matching the ripple peaks for the filter, and will typical be slightly above 1.
M = Coeffs_resolution-1 + floor(log2(0.5/max(taps)))
Max_filter_ripple = 10^(Max_filter_ripple_in_dB/2/20), Max_filter_ripple_in_dB is peak-to_peak.
MSBs to remove = ceil(log2(length(taps))) + 1 - floor(log2(0.5/max(taps)))
For the filter above, with Coeffs_resolution = 24
M=24, Max_filter_ripple = 1.0058 (with Max_filter_ripple_in_dB=0.1dB)
At the output:
Remove 5 MSB
Remove 24 LSB
I have tested this approach on a 3-stage decimation filter and I get a gain of 0.98.
BR
AD
- CheepinC_altera6 years ago
Hi AD, Glad to hear that you have managed to resolve the issue and thanks lot for your sharing on the detailed implementation. It is really helpful. Thank you. Best regards, Chee Pin
