ArthurDent
7 years agoFIR Filter II, not able to get unity gain
Hi I have designed a 26 taps FIR filter in Matlab. The coefficients are float (between -1 to 1) and the sum of the coefficient is close to 1 ( sum(taps) = 0.9991 ). In FIR II IP generator (Quartu...
CheepinC_altera
7 years agoHi AD,
For your information, I have had some discussion with peers on this. Based on our discussion, the your undersing on the calculation on the full output range and the number of bits for representing sum of coefficients seems correct.
Regarding your specific inquiries on the MSB and LSB to remove, sorry as I do not have much insight into this and thus might not be able to provide any helpful comment. As a workaround, it is recommended for you to try with different truncation in simulation to see if can achieve your target requirement. Sorry for the inconvenience.
Chee Pin
