15 years agoFIR filter coefficient scaling and downscaling
I have a sensor signal which is unsigned 12 bits and i need to filter the signal using a FIR filter. The filtered output feeds into an algorithm which expects 12bit unsigned input. I have used...
15 years agoThe sum of coeff is 51519. Do you think some thing is not set right in the fir compiler setting. I am using the following settings:
Input Number System : unsigned binary Input Bit Width: 12 Coeffecients scaling: Auto Bit width 12 Structure: fully Parallel filter.
