11 years agofir_compiler+ii error id 15008
I have created a decimation filter using MegaCore FIR Compiler II, this produces the frequency plot I want and compiles without errors.
When I add this to my design in Quartus and compile I get the following error messages:- 15008 MLAB "dsp_block:inst 27| ................. |altsyncram_atv3:auto_generated|lutrama0" on port "Port A, data In" has illegal width "0". The correct width is "1" 15010 MLAB "dsp_block:inst 27| ................. |altsyncram_atv3:auto_generated|lutrama0" is implementing memory in non-ROM mode, but the port "Port A, Data In" is not connected 15464 WYSIWYG primitive "dsp_block:inst 27| ................. |altsyncram_atv3:auto_generated|lutrama0" has mismatched parameters for port Port A, Data In Any help on how to fix this would be much appreciated Using Quartus V14.0 Device Cyclone V 5CSEBA6U23I7 filter.vhd -- Generated by Altera MegaWizard Launcher Utility version 1.0 -- ************************************************************ -- THIS IS A WIZARD-GENERATED FILE. DO NOT EDIT THIS FILE! -- ************************************************************ -- Copyright (C) 1991-2015 Altera Corporation -- Any megafunction design, and related net list (encrypted or decrypted), -- support information, device programming or simulation file, and any other -- associated documentation or information provided by Altera or a partner -- under Altera's Megafunction Partnership Program may be used only to -- program PLD devices (but not masked PLD devices) from Altera. Any other -- use of such megafunction design, net list, support information, device -- programming or simulation file, or any other related documentation or -- information is prohibited for any other purpose, including, but not -- limited to modification, reverse engineering, de-compiling, or use with -- any other silicon devices, unless such use is explicitly licensed under -- a separate agreement with Altera or a megafunction partner. Title to -- the intellectual property, including patents, copyrights, trademarks, -- trade secrets, or maskworks, embodied in any such megafunction design, -- net list, support information, device programming or simulation file, or -- any other related documentation or information provided by Altera or a -- megafunction partner, remains with Altera, the megafunction partner, or -- their respective licensors. No other licenses, including any licenses -- needed under any third party's intellectual property, are provided herein. ----> -- Retrieval info: <instance entity-name="altera_fir_compiler_ii" version="14.0" > -- Retrieval info: <generic name="deviceFamily" value="Cyclone V" /> -- Retrieval info: <generic name="filterType" value="Decimation" /> -- Retrieval info: <generic name="interpFactor" value="1" /> -- Retrieval info: <generic name="decimFactor" value="8" /> -- Retrieval info: <generic name="L_bandsFilter" value="All taps" /> -- Retrieval info: <generic name="clockRate" value="16" /> -- Retrieval info: <generic name="clockSlack" value="0" /> -- Retrieval info: <generic name="speedGrade" value="Medium" /> -- Retrieval info: <generic name="coeffReload" value="false" /> -- Retrieval info: <generic name="baseAddress" value="0" /> -- Retrieval info: <generic name="readWriteMode" value="Read/Write" /> -- Retrieval info: <generic name="backPressure" value="false" /> -- Retrieval info: <generic name="symmetryMode" value="Symmetrical" /> -- Retrieval info: <generic name="delayRAMBlockThreshold" value="20" /> -- Retrieval info: <generic name="dualMemDistRAMThreshold" value="1280" /> -- Retrieval info: <generic name="mRAMThreshold" value="1000000" /> -- Retrieval info: <generic name="hardMultiplierThreshold" value="-1" /> -- Retrieval info: <generic name="inputRate" value="16" /> -- Retrieval info: <generic name="inputChannelNum" value="1" /> -- Retrieval info: <generic name="inputType" value="Signed Binary" /> -- Retrieval info: <generic name="inputBitWidth" value="16" /> -- Retrieval info: <generic name="inputFracBitWidth" value="0" /> -- Retrieval info: <generic name="coeffSetRealValue" value="4.0,7.0,8.0,8.0,5.0,-1.0,-12.0,-29.0,-50.0,-77.0,-107.0,-138.0,-166.0,-188.0,-199.0,-192.0,-163.0,-106.0,-18.0,104.0,260.0,450.0,668.0,909.0,1165.0,1424.0,1677.0,1911.0,2114.0,2277.0,2390.0,2449.0,2449.0,2390.0,2277.0,2114.0,1911.0,1677.0,1424.0,1165.0,909.0,668.0,450.0,260.0,104.0,-18.0,-106.0,-163.0,-192.0,-199.0,-188.0,-166.0,-138.0,-107.0,-77.0,-50.0,-29.0,-12.0,-1.0,5.0,8.0,8.0,7.0,4.0" /> -- Retrieval info: <generic name="coeffType" value="Signed Binary" /> -- Retrieval info: <generic name="coeffScaling" value="None" /> -- Retrieval info: <generic name="coeffBitWidth" value="16" /> -- Retrieval info: <generic name="coeffFracBitWidth" value="15" /> -- Retrieval info: <generic name="outType" value="Signed Binary" /> -- Retrieval info: <generic name="outMSBRound" value="Saturating" /> -- Retrieval info: <generic name="outMsbBitRem" value="7" /> -- Retrieval info: <generic name="outLSBRound" value="Rounding" /> -- Retrieval info: <generic name="outLsbBitRem" value="15" /> -- Retrieval info: <generic name="resoureEstimation" value="1000,1200,10" /> -- Retrieval info: <generic name="bankCount" value="1" /> -- Retrieval info: <generic name="bankDisplay" value="0" /> -- Retrieval info: </instance> -- IPFS_FILES : NONENo RepliesBe the first to reply
