14 years agoFIR Compiler v9.1 simulation trouble
I'm currently tasked with FPGA design on an Altera EP3C25F256I7N part. we're considering buying a license for the Megafunction FIR Complier v9.1. I'm trying to evaluate the performance of this module but haven't been able to simulate with ModelSim. Is this expected? If we purchase a license will we be able to simulate with ModelSim then?
Here is what I'm seeing. I'm working with Quartus II Version 9.1 Web Edition with Service Pack 2 installed. If I enable simulation with my project by navigating Quartus to Assignments->EDA Tool Settings…->Simulation and set Tool name: to ModelSim-Altera. Once I compile my project, at the EDA Netlist Writer task, errors result. I've entered example text below. If the above mentioned setting is set to "none" my project compiles fine. I can program a target via JTAG and see that it seems to be working. Error: Can't generate net list output file because the file "Z:/Documents/Li7800 Development/Li6800_fir_test/megafunction/fir_complier-library/mr_accum_wr.v" is an OpenCore Plus time-limited file … … Many more like the error above … … Error: Can't generate net list output file because the license for encrypted file "Z:/Documents/Li7800 Development/Li6800_fir_test/megafunction/fir_complier-library/mr_accum_wr.v" is not available … … Many more like the error above Has anyone used the Megafunction FIR compiler v9.1 and been able to simulate with it? Thanks in advance for your help.1 Reply
you can simulate the IP itself without a license by following the instructions in the User Guide. you will not be able to run EDA Netlist Writer to create a gate level netlist for simulation without purchasing the IP
