17 years agoFIR Compiler troubles
Hi, Help is needed. I am trying to design a system with a filter; I’m using the FIR Compiler to generate the filter component. At this moment I’m just experimenting by choosing different f...
17 years ago --- Quote Start --- First two warnings are related to bit width of FIR filter coefficients due to no scaling. There's no problem with this. But, i'm not sure about input warnings, this connection isn't clear in image. --- Quote End --- Thank you very much, parrado. What else should I check to make it clear what can cause the input warnings?
