17 years agoFIR Compiler Problem
I'm trying to design a simple FIR System but I don't understand how the FIR-Filter designed with the FIR Compiler works. As you can see in the .bdf File in the zip archive. Do I have to use a different clock for the FIR_const or do I have to reset it in a special way? The input is an external generated 7 MHz Sinus.. Thanks P.S. an example bdf of an FIR Filter in that way would be also very helpful for me ;-)No RepliesBe the first to reply
