10 years agoFIR compiler II syntax error
I am using quartus 15.1 to generate a fir ii core. I chose the verilog option for the cores language.
I am using candace tools to elaborate and simulate a design with the generated FIR II core. Here are the options I am using when I elaborate and simulate my design irun: 14.10-s021: (c) Copyright 1995-2015 Cadence Design Systems, Inc. TOOL: irun 14.10-s021: Started on Jun 23, 2016 at 16:49:19 EDT irun -cdslib cds.lib -hdlvar hdl.var -access +c -smartorder -status -v93 -work worklib -input scripts/tb_tx_filters.tcl -top tb_tx_filters -vlogext .vo,.VO,.vp,.VP -vhdlext .vho,.VHO -nostdout -clean -l logs/irun.log -makelib shlslib During the elaboration phase I get the following error../../../../ip_cores/core_files/fir_interpolate8/fir_interpolate8_sim/auk_dspip_roundsat_hpfir.vhd: max_val <= (IN_WIDTH_g-REM_LSB_BIT_g-REM_MSB_BIT_g-1 => '0', others => '1'); | ncvhdl_p: *E,AGNLSC (../../../../ip_cores/core_files/fir_interpolate8/fir_interpolate8_sim/auk_dspip_roundsat_hpfir.vhd,143|54): non-locally static or null range choice must be only choice [7.3.2.2]. max_val <= (IN_WIDTH_g-REM_LSB_BIT_g-REM_MSB_BIT_g-1 => '0', others => '1'); | ncvhdl_p: *E,AGNLSC (../../../../ip_cores/core_files/fir_interpolate8/fir_interpolate8_sim/auk_dspip_roundsat_hpfir.vhd,143|70): non-locally static or null range choice must be only choice [7.3.2.2]. min_val <= (IN_WIDTH_g-REM_LSB_BIT_g-REM_MSB_BIT_g-1 => '1', others => '0'); | ncvhdl_p: *E,AGNLSC (../../../../ip_cores/core_files/fir_interpolate8/fir_interpolate8_sim/auk_dspip_roundsat_hpfir.vhd,144|54): non-locally static or null range choice must be only choice [7.3.2.2]. min_val <= (IN_WIDTH_g-REM_LSB_BIT_g-REM_MSB_BIT_g-1 => '1', others => '0'); | ncvhdl_p: *E,AGNLSC (../../../../ip_cores/core_files/fir_interpolate8/fir_interpolate8_sim/auk_dspip_roundsat_hpfir.vhd,144|70): non-locally static or null range choice must be only choice [7.3.2.2]. errors: 4, warnings: 0 This is the section of the file auk_dspip_roundsat_hpfir.vhd causing the error. ----------------------------------------------------------------------------- -- msb : trunc/saturation ----------------------------------------------------------------------------- remove_msb: if REM_MSB_BIT_g > 0 generate signal min_val, max_val : std_logic_vector(IN_WIDTH_g-REM_LSB_BIT_g-REM_MSB_BIT_g-1 downto 0); begin trunc_msb: if REM_MSB_TYPE_g = "trunc" generate begin data_msb <= data_lsb(IN_WIDTH_g-REM_LSB_BIT_g-REM_MSB_BIT_g-1 downto 0); dataout <= data_msb; valid <= valid_lsb; end generate trunc_msb; sat_msb: if REM_MSB_TYPE_g = "sat" generate max_val <= (IN_WIDTH_g-REM_LSB_BIT_g-REM_MSB_BIT_g-1 => '0', others => '1'); min_val <= (IN_WIDTH_g-REM_LSB_BIT_g-REM_MSB_BIT_g-1 => '1', others => '0'); data_msb <= std_logic_vector(max_val) when signed(data_lsb) > signed(max_val) else std_logic_vector(min_val) when signed(data_lsb) < signed(min_val) else data_lsb(IN_WIDTH_g-REM_LSB_BIT_g-REM_MSB_BIT_g-1 downto 0); msb_p : process (clk, reset_n) begin if reset_n = '0' then dataout <= (others => '0'); valid <= '0'; elsif rising_edge(clk) then if valid_lsb = '1' then dataout <= data_msb; end if; valid <= valid_lsb; end if; end process msb_p; end generate sat_msb; end generate remove_msb; how can i resolve these errors so my design will elaborate the fir ii core?No RepliesBe the first to reply
