11 years agoFIR compiler II parameter settings for sample rates below 1Mhz
Hello, i am trying to set the FIR Compiler II parameters to accomplish the following operation. interpolation factor: 5 decimation factor: 2 channels: 6 input sample rate ( per chann...
11 years agoThe tool should only know the ratio of clock to sample rate. It would be silly if it doesn't. I tried with fir compiler and entered fractions for clock and sample rate and was accepted though it says MHz in brackets.
