16 years agoFIR Compiler 9.1 generate incorrect outputs
Hi, I created a simple simulink model using DSP builder 9.1 sp1 blocks. The model runs at 120Mhz with 20.02Mhz input signal. After generating 20Mhz cos and sin signals from NCO block, the...
16 years agoKaz,
Please see the attached both I_out and Q_out samples. Before opening, you need to rename the extension to .mat format. I collected 12000 samples from both. Thanks. Tim
