16 years agoFIR Compiler 9.1 generate incorrect outputs
Hi, I created a simple simulink model using DSP builder 9.1 sp1 blocks. The model runs at 120Mhz with 20.02Mhz input signal. After generating 20Mhz cos and sin signals from NCO block, the...
16 years agoIt might help if you send me text file of your output data
