16 years agoFIR Compiler 9.1 generate incorrect outputs
Hi, I created a simple simulink model using DSP builder 9.1 sp1 blocks. The model runs at 120Mhz with 20.02Mhz input signal. After generating 20Mhz cos and sin signals from NCO block, the...
16 years agoThank you for your comment.
I collected many samples to see the pattern, but I couldn't see proper filter output. Also, FFT scope shows incorrect result, too. Could you run this model in your machine if available? Thanks again. Tim
