16 years agoFIR Compiler 9.1 generate incorrect outputs
Hi, I created a simple simulink model using DSP builder 9.1 sp1 blocks. The model runs at 120Mhz with 20.02Mhz input signal. After generating 20Mhz cos and sin signals from NCO block, the...
16 years agoI don't have your tools but as you said, you get -0.02MHz and 40.02MHz.
I checked your filter coefficients and it works and removes 40.02MHz. You are left with -0.02MHz. Your 0.02MHz will need several thousand samples to show one period. May be you are looking at few samples.
