11 years agoFIR and CIC MegaCores Altogether
Hi, I have instantiated FIR II MegaCore as a Pulse-Shaping and upsampling by 8 filter, now I want to use CIC MegaCore after FIR to interpolate the signal... I didn't use Back Pressure feature in...
11 years agoI solved it KAZ :D
I did what you suggested... using FIFO... You are GENIUS! So this is the new configuration: https://www.alteraforum.com/forum/attachment.php?attachmentid=10278 And SignalTap shows exactly what I want: https://www.alteraforum.com/forum/attachment.php?attachmentid=10279 To satisfy ourselves... here is the signal before interpolation (RRC output): https://www.alteraforum.com/forum/attachment.php?attachmentid=10280 And this is after interpolation: https://www.alteraforum.com/forum/attachment.php?attachmentid=10281 Thank you again :)
