11 years agoFIR and CIC MegaCores Altogether
Hi, I have instantiated FIR II MegaCore as a Pulse-Shaping and upsampling by 8 filter, now I want to use CIC MegaCore after FIR to interpolate the signal... I didn't use Back Pressure feature in...
11 years agoMy original data rate is 176.4 KHz, and I want to raise to to 100 MHz so that I can multiply it with the carrier signal.
that means an interpolation factor of 566!!! Isn't that too much?! I wish I could do it in a single stage but I thought it would be a waste of resources. If you recommend it I will do it :) EDIT: I've just checked the FIR compiler... it doesn't have such a factor. Maximum is 128.
