16 years agoFIR 2D behavioural
Hi all I have a question about VIP 2D Filter. If I configure it to work on color planes in sequence, Luminance and Chromas (YCbCr4:2:2), how does it work onto the Chroma(s) signal? Reading th...
15 years ago>shouldn't be
>din0 C >din1 Y >dout0 [7:0] C >dout0 [15:8] Y The control packet used by the joiner is the control packet from din0 by default. This is the reason why I suggested to plug the Y channel back to din0 rather than din1. Otherwise, the wrong control packet (with half the width) will be propagated. Your choice for the output is fine if you wish to output 4:2:2 in parallel.
