16 years agoFIR 2D behavioural
Hi all I have a question about VIP 2D Filter. If I configure it to work on color planes in sequence, Luminance and Chromas (YCbCr4:2:2), how does it work onto the Chroma(s) signal? Reading th...
15 years ago --- Quote Start --- splitter din0 is C Y, dout0 should be C and you should halve the width of the control packets dout1 should be Y --- Quote End --- That is the correct endianess. But why, for the joiner, you said --- Quote Start --- For the joiner: din0 should be y
din1 should be c dout0 should be C Y and the source of non-image packet should be din0 --- Quote End --- shouldn't be din0 C din1 Y dout0 [7:0] C dout0 [15:8] Y ?
