16 years agoFIR 2D behavioural
Hi all I have a question about VIP 2D Filter. If I configure it to work on color planes in sequence, Luminance and Chromas (YCbCr4:2:2), how does it work onto the Chroma(s) signal? Reading th...
16 years agoI think the following will work but perhaps you should confirm that the IP is doing the right thing:
For the splitter: din0 is C Y, please make sure that this is the correct order in time (or correct endianess if in parallel) dout0 should be C and you should halve the width of the control packets dout1 should be Y A slightly different way of doing the same thing is given in the VIP user guide with the 2 pixels per port option For the joiner: din0 should be Y din1 should be C dout0 should be C Y and the source of non-image packet should be din0
