16 years agoFIR 2D behavioural
Hi all I have a question about VIP 2D Filter. If I configure it to work on color planes in sequence, Luminance and Chromas (YCbCr4:2:2), how does it work onto the Chroma(s) signal? Reading th...
16 years ago> I get an elaboration ONLY on the luma plane?
I may have misunderstood your question but I think the answer is no. If you attempt to send YCbCr 4:2:2 into the 2DFIR you will have to parameterize the input as two channels in sequence Y, C. The 2DFIR filter does not understand subsampled data and it only sees a second fully sampled color plane C. Consequently, the filter would smear the Cb and Cr planes onto each other. What I was suggesting was that: 4:2:2 (seq or par) -> VIP_ColorPlaneSequencer (splitter) -> 1 + 2 1) FIR on Y (1 seq) -> Fifo(*) -> 3 2) FIR on Cb,Cr (2 seq) -> Fifo(*) -> 4 3 + 4 -> VIP_ColorPlaneSequencer (join) -> 4:2:2 (sequence or parallel) *Fifos may be necessary in case of throughput issues
