16 years agoFilter output value is lower than expected
Hi, I have a fir compiler with the following settings: Input Bit Width: 16 Coefficient Scaling: Auto with 16 Bits Filter Type: LP with 37 Coefficients Sample Rate: ...
16 years agosince you are truncating 17 bits,in effect you are dividing the sum of internal products by 2^17. Thus if you scale your coeffs as:
coeff = coeff/sum(coeff) *2^17 then you should get unity dc gain. but what actually happens at 1MHz may be due to your response
