11 years agoFIFO write, data and wreq
Hi! I want to write into alter FIFO from state machine. I have registered data and wrreq signals. Now i am wondering, is it unsafe to set them both on the same clock cycle? Or should i set da...
11 years ago --- Quote Start --- I think the confusion is the result of timing diagrams being functional so you are not seeing typical register switching wire/logic delays. I have attached a timing diagram that shows what the typical timing is (minus the full and empty signals). So the value 0 is written in just before the 2nd red line. Two cycles after the first write the data should be available at the output and the empty signal de-asserts which is when it's safe to start reading from the FIFO. When rdreq is asserted the FIFO is popped, and the next data becomes available. --- Quote End --- Thank you,this helped me understand :)
