16 years agofifo-less triple speed ethernet
Hello, Due to latency problem, I have to use Triple speed ethernet without internal fifos. Nevertheless, I have no piece of information about how to plug "receive_packet_type_0" or "receive_fifo_...
16 years agoHello again...
I did some tests and i get this results : - receive stream : - 8 bits data signal - 1 bit ready signal - 1 bit valid signal - 5 bits error signal - 1 bit sop - 1 bit eop [/INDENT][/INDENT]- transmit stream : - 8 bits data signal - 1 bit ready signal - 1 bit valid signal - 1 bit error signal - 1 bit sop - 1 bit eop [/INDENT][/INDENT]- receive_packet_type : - 1 bit valid signal - 5 bit data signal [/INDENT][/INDENT]- receive_fifo_status : - 2 bits data signal - 1 bit valid signal [/INDENT][/INDENT]but i still don't know what's in the two last streams receive_fifo_status and receive_packet_type... and i still don't have any piece of information... Could anyone help? Thanks.
