10 years agoFIFO IP is getting empty at a faster rate
Hi, I'm using a FIFO IP with width of the fifo being 16 bit and the depth of the fifo buffer is 16384 words. I'm using the MAX10 development kit and interfacing it with Matlab. The baud rate is...
10 years agoswarnava9 -
Do you know how to use SignalTap? SignalTap will show you very quickly what's happening. I'm assuming here that SignalTap works in MAX10 devices (I've never used MAX10).
