10 years agoFIFO IP is getting empty at a faster rate
Hi, I'm using a FIFO IP with width of the fifo being 16 bit and the depth of the fifo buffer is 16384 words. I'm using the MAX10 development kit and interfacing it with Matlab. The baud rate is...
10 years agoHi,
Thanks for your reply, I did use the UART core and set the baud rate to 115200 bps and also have taken care of FIFO overflow and underflow. Whenever the fifo gets empty, it'll automatically gets filled up, the code works this way. Thanks,
