10 years agoFIFO IP is getting empty at a faster rate
Hi, I'm using a FIFO IP with width of the fifo being 16 bit and the depth of the fifo buffer is 16384 words. I'm using the MAX10 development kit and interfacing it with Matlab. The baud rate is...
10 years agoDid you use an UART Core inside MAX10 to receive or send data from/to Rx/Tx pins ? Did you set the baud rate of UART core to 115200 bps?? have you taken care of FIFO overflow?
