10 years agoFIFO filling up after 2 writes
Hi, I'm using a 32 bit FIFO set to show-ahead, to cross clock domains from a fast clock to a slower clock. The FIFO is empty and i clock in two 32 bit words, i invert the rdempty signal a...
10 years agoDid you write your own FIFO logic?
It seems that the extra read cycle from the second read causing the FIFO counter to loop (overflow) to maximum value of 1023. If you write your own logic, you might want to detect the counter == 0 and prevent the read.
