11 years agoFFT_verification
Hi ! When I run FFT and IFFT tool in megawizard, the results are not logical. For example firstly I run the FFT tool with the megawizard tb (input: natural order, output : digit reversed order)...
11 years agoI used the output of FFT for the input of IFFT.I mean I modified the tb for IFFT.
By the way I found the solution ;) When you check in binary for floating point it is hard to find what is wrong. When I converted to decimals in Matlab I saw that the output multiplied with the FFT size. For example if you use 8-IFFT the outputs are 8 time greater than the outputs had used to be. You should normalize them by IFFT size ;) Thanks anyway for your reply
