13 years agoFFT Variable Streaming (Fixed Point) output scaling
I would like to know if my output scaling is correct if the configuration of FFT MegaCore v12.1 as follows.
Transform Length : 2048 Data Input Precision : 18 Twiddle Precision : 18 Data Output Precision : 30 I/O Data Flow : Variable Streaming Input Order : Natural Order Output Order : Natural Order Data Representation : Fixed Point Since the above configuration outputs a natural bit growth (as stated in the userguide), is it okay to scale the output by bit shifting to the right by 12bits and round-off the discarded LSB's to one bit and add it to the MSB's? Thank you. zeahrNo RepliesBe the first to reply
