11 years agoFFT_testbench_matlab_model
Hi ! I am using FFT 13.0 megacore function for the IFFT end FFT. The modelsim results and the matlab m file results obtained by the megawizard created are the same. However when I use the "if...
11 years agoHow do you compare the iFFT result with Matlab? Is that you prefer FFT-> iFFT? if this is the case, what is the I/O order?
