11 years agoFFT_testbench_matlab_model
Hi ! I am using FFT 13.0 megacore function for the IFFT end FFT. The modelsim results and the matlab m file results obtained by the megawizard created are the same. However when I use the "if...
11 years ago --- Quote Start --- I am using FFT 13.0 megacore function for the IFFT end FFT. The modelsim results and the matlab m file results obtained by the megawizard created are the same. --- Quote End --- Because these two models are bit-accurate, i.e., the MATLAB model matches the calculations used by the HDL. --- Quote Start --- However when I use the "ifft" function in matlab it differs. --- Quote End --- That is to be expected, since the MATLAB fft/ifft routines use floating-point math and may have different scale factors. Here's a document showing how the Altera FFT matches the MATLAB fft within the quantization noise floor of the fixed-point data being transformed; https://www.ovro.caltech.edu/~dwh/correlator/pdf/fft_tutorial.pdf This document has some slides with hardware FFTs (pages 50-54) https://www.ovro.caltech.edu/~dwh/correlator/pdf/hawkins_jpl_2014.pdf and this has more (page 85-99) https://www.ovro.caltech.edu/~dwh/correlator/pdf/ee_live_14_hawkins.pdf The Altera FFT is a streaming FFT. You can download the He and Torkelson paper referenced in the User Guide and it explains the operation. --- Quote Start --- What is the "SVSfftmodel" that magacore matlab m file uses. --- Quote End --- The bit-accurate model that implements the Altera FFT. --- Quote Start --- How does that model works? --- Quote End --- That is part of Altera's "secret", but if you read the tutorial linked above, you'll see pretty much how it probably works. Cheers, Dave
