11 years agoFFT problem. Simulation vs HW's execution
Hi, I'm having some problems with the utilization of the FFT IP from altera. I have a architecture that uses 4 FFTs in paralel. The simulation in the modelsim the project is doing fine. But when I've...
11 years agofreeze the fpga using freezing spray (not ice blocks). Brings temperature down to zero or so and see if design shows any improvement by monitoring the outputs of ffts.
If so it is viewed as definite test of timing failure.
