11 years agoFFT problem. Simulation vs HW's execution
Hi, I'm having some problems with the utilization of the FFT IP from altera. I have a architecture that uses 4 FFTs in paralel. The simulation in the modelsim the project is doing fine. But when I've...
11 years agoIf timing report is ok then at least we know that internal logic (fft) should behave well at any speed up to fmax.
If io constraints are not right but you are not reading them in your analysis (rather you read inputs/outputs of fft directly) then you can ignore io for now. try freezer testing if it forces a change.
