11 years agoFFT problem. Simulation vs HW's execution
Hi, I'm having some problems with the utilization of the FFT IP from altera. I have a architecture that uses 4 FFTs in paralel. The simulation in the modelsim the project is doing fine. But when I've...
11 years agoWe really belive that the control is correct. Maybe the GIDEL plataform are reading the data in a wrong way, but I believe we are facing timimg problems, because using the frequency at 125MHz and 250MHz the plataform is doing fine. But only in this two frequency. In the sdc I've requested 250 MHz in the clock that is going to be used in my top module. So if I configure the clock to 100MHz, for example, the outputs of the FFTs are differents.
